  3. dbid:removed
  • Subscribers 160
  • Views 2776
dbid:removed
aeris
aeris over 13 years ago
anyone encountered a scenario similar to this
-- you cant debug because the dbid were instantly removed the moment you assign them to a variable
function/procedure as simple as this :
(defun MyTest ()
 axlSetFindFilter(?enabled list("noALL" "pins" "vias" "shapes") ?onButtons list("noALL" "shapes"))
 axlAddSelectAll()
 retDbid=axlGetSelSet()
axlMsgPut("%L" retDbid)
  1. I normally get dbids when I put retDbid in the skill command prompt, until lately im having this problem. The axlMsgPut shows all the dbid's value, but in my skill command prompt i have all the dbids removed
  2. Running the program as a whole have no error, its just that I cant debug dbid values
I have tried the following
1. Use same code to other PC -- normal as expected
2. Re-install allegro within the same pc with error -- still have error
  • Pawandeep
    Pawandeep over 13 years ago
    You don’t need to reinstall applications as you are observing this on certain program only.
    Try the hit and trial method
    1.       Try it on a different design on the same pc
    2.       Try changing the variable name
    3.       See if your program works for some other filtered list like pins/vias.
  • aeris
    thanks Pawan, but already tried those, I'm hoping  that someone would tell me that i accidentally turned some functions on/off in allegro setup reference
    whats really bugging me is that, same code can be debugged in other pc
    edit:
    any object that im trying to gets its dbid are always removed, and this is for all my functions/procedures
  • Pawandeep
    Hmm…. Try to remove all the skill files(*.il)  from your directories first before invoking Allegro. May be you are having old skill file that is invoked from somewhere from your skill path
  • aeris
    yup i have tried that, and have used axlMsg commands as well as axlUIConfirm to check the data of dbids -- these commands yields correct value, but those dbids are remove the moment i checked in skill command prompt
  • GIL2004XP
    GIL2004XP over 13 years ago
    I've tried running your code and gives me the same result as what you are experiencing so I wonder if this is just a normal condition when running it as a whole.
    But if you tried running your code line by line will let you analyse each dbid in retDbid
