  3. Single Form Instance
  • Views 14368
GIL2004XP
GIL2004XP over 14 years ago
 How do you keep your Form from opening multiple times?
  • fxffxf
    fxffxf over 14 years ago
    see example code in <cdsroot>/share/pcb/examples/skill/cmds/cns-design.il
    Need a unique global form handle:
        ; doing this prevents multiple instances of form from opening
        unless(boundp('_AcDesignFw) _AcDesignFw = nil
    Then at top of your code's entry point (this code needs to use prog statements instead of let to allow return):
         ;; Good pratice - If form is open expose it and return
        fw = _AcDesignFw
        when( fw
        axlUIWExpose(fw)
        return(t)
  • GIL2004XP
     Thank You. Works perfectly as expected.
