  3. autosilkUtils.il
  • Replies 38
  • Subscribers 166
  • Views 36178
autosilkUtils.il
FormerMember
FormerMember over 14 years ago
 Hi All:
Hopefully Dave Elder reads this ?
I am running Allegro 16.5  S018 and tried to run the autosilkUtils.il SKILL script.
Everything seems to work except it does not put the DRCs into the walker popup window.
Hopefully someone can fix this ?
This is a great tool
Les
  • DE202408202727
    DE202408202727 over 14 years ago +1
    Hi Les, It should work. What version number does the utility show in the form? Versions after 8.23 are suitable for 16.5 although my latest (unreleased version is 11.04) Dave
  • FormerMember
    FormerMember over 14 years ago +1
    8.12
  • FormerMember
    8.12 from Allegro SKILL Code Library
  • pcbnagaraj
    pcbnagaraj over 14 years ago
    Dave,
    I am getting the error when my board outline is created as shapes. They are the designs templates.
    Is this a limitation or can you help in getting this fixed?
    E- (SPMHDB-185): Filled SHAPE may not exist on layer 'BOARD GEOMETRY/OUTLINE'.
    E- *Error* plus: can't handle (nil + nil)
    TIA.
    Nagaraj.
  • DE202408202727
    This is an Allegro limitation. You cannot have filled shapes on the BOARD GEOMETRY/OUTLINE layer.
  • pcbnagaraj
    Dave,
    I don’t have any filled shapes in board geometry. But I have board outline created as unfilled shape.
    When I run silk skill I get the error message.
    Nagaraj.
  • DE202408202727
    Hi Nagaraj,
    There is no problem having your outline as a shape.
    What function are you running? Can you please me send a screenshot?
    Dave
  • pcbnagaraj
    Nagaraj.
