  3. autosilkUtils.il
  • Replies 38
  • Subscribers 166
  • Views 36183
autosilkUtils.il
FormerMember
FormerMember over 14 years ago
 Hi All:
Hopefully Dave Elder reads this ?
I am running Allegro 16.5  S018 and tried to run the autosilkUtils.il SKILL script.
Everything seems to work except it does not put the DRCs into the walker popup window.
Hopefully someone can fix this ?
This is a great tool
Les
  • DE202408202727
    DE202408202727 over 14 years ago +1
    Hi Les, It should work. What version number does the utility show in the form? Versions after 8.23 are suitable for 16.5 although my latest (unreleased version is 11.04) Dave
  • FormerMember
    FormerMember over 14 years ago +1
    8.12
  • FormerMember
    8.12 from Allegro SKILL Code Library
  • pcbnagaraj
    pcbnagaraj over 14 years ago
    Dave
    I attached the snap shot/error in my previous post.
    /forums/p/22199/1312162.aspx#1312162
    Nagaraj.
  • DE202408202727
    Do you have BOARD GEOMETRY/OUTLINE in a silkscreen film list?
    Please snapshot the other tab too.
  • pcbnagaraj
    Yes
    Nagaraj.
  • pcbnagaraj
    Here is the snap shot.
    I appreciate your time in helping for this issue.
    We have included the Board outline in all films.
    Nagaraj.
  • DE202408202727
    Ok. The quick answer is that the code doesn't handle text on the Outline layer if that's included in the layers to check.
    Presumable you have text in a title block?
    I'll need to review the code to handle this. In the meantime, try moving the text to a user-defined layer and add that layer to your artwork.
    If you don't have text on the Outline layer, please let me know what IS there.
    Dave
