  3. autosilkUtils.il
  • Replies 38
  • Subscribers 166
  • Views 36190
autosilkUtils.il
FormerMember
FormerMember over 14 years ago
 Hi All:
Hopefully Dave Elder reads this ?
I am running Allegro 16.5  S018 and tried to run the autosilkUtils.il SKILL script.
Everything seems to work except it does not put the DRCs into the walker popup window.
Hopefully someone can fix this ?
This is a great tool
Les
  • DE202408202727
    DE202408202727 over 14 years ago +1
    Hi Les, It should work. What version number does the utility show in the form? Versions after 8.23 are suitable for 16.5 although my latest (unreleased version is 11.04) Dave
  • FormerMember
    FormerMember over 14 years ago +1
    8.12
  • FormerMember
    8.12 from Allegro SKILL Code Library
  • pcbnagaraj
    pcbnagaraj over 14 years ago
    Dave,
    No text on Board geometry outline.
    I used the axlSetFindFilter and enabled all and used only board geometry/outline.
    By addSelectAll() verified, only dbid returned and that’s for shapes.
    I have only shapes on board geometry/outline layer which is included in silk artwork causing error.
    Nagaraj.
  • pcbnagaraj
    Dave,
    Here is my silk artwork film settings.
    I have no text on Board Geometry/ Outline.
    Nagaraj.
  • Mstrghettorigg
    Mstrghettorigg over 14 years ago
    Hi Dave,
    I saw this post and I tried using your skill.  It seems that I can get the file to load, but can't get it to run.  Am I missing a step somewhere?  I've attached the image of the command line.  I can run other skill files just fine also.
     I am on 16.3
    Please advise at your convenience.
    I like to add that version 8.24  I found on an older post is working.
  • s8888
    s8888 over 13 years ago
    I downloaded the skill script copied to project folder.
    Running script using below command
    skill load "autosilkUtils.il "
    enter
    script is running but i am not finding any difference in silk arrangement.
     Please let me know whether steps i have followed is correct.
  • DE202408202727
    DE202408202727 over 13 years ago
    Read the instructions in the header of the file. You will need to do more than just loading the file.
