  3. autosilkUtils.il
  • Replies 38
  • Subscribers 166
  • Views 36199
autosilkUtils.il
FormerMember
FormerMember over 14 years ago
 Hi All:
Hopefully Dave Elder reads this ?
I am running Allegro 16.5  S018 and tried to run the autosilkUtils.il SKILL script.
Everything seems to work except it does not put the DRCs into the walker popup window.
Hopefully someone can fix this ?
This is a great tool
Les
  • DE202408202727
    DE202408202727 over 14 years ago +1
    Hi Les, It should work. What version number does the utility show in the form? Versions after 8.23 are suitable for 16.5 although my latest (unreleased version is 11.04) Dave
  • FormerMember
    FormerMember over 14 years ago +1
    8.12
  • FormerMember
    8.12 from Allegro SKILL Code Library
  • s8888
    s8888 over 13 years ago
    Sorry to trouble you again.
    Can u send me file with instruction in  header.
    I am not finding any instruction in the file what i have.
    Thank you
  • DE202408202727
    DE202408202727 over 13 years ago
    You are correct. Iinstructions are not in the header.
     Place the context file in your skill folder.
    Add loadContext("AutosilkUtils_public16.5.cxt") to the allegro.ilinit file in your pcbenv folder.
    Add axlCmdRegister("silkutils" 'ASU_start ?cmdType "interactive") to the allegro.ilinit file.
    Run  "silkutils" on the Allegro command line.
    AutosilkUtils_public16.5.zip
  • s8888
    But i am not finding any allegro.ilinit file in my pcbenv.
    Also you have mentioned toPlace the context file in skill folder. Is this project folder location or skill folder located in C:\Cadence\SPB_16.3\tools.
  • DE202408202727
    OK.
    Firstly, use the attached code for 16.3.
    Unzip it and place it in the  skill folder underneath the folder defined by your allegro_site environment variable. (You may need to create the folder).
    Create the allegro.ilinit file (in the same folder) if it doesn't exist.
    Add the two lines:
    load("AutosilkUtils_public.il")
    autosilkUtils_public.zip
  • s8888
    As per your advice i created folder as shown below in C drive, Created allegro.ilinit & placed skill file with in that
    C:\Cadence\SPB_16.3\allegro_site environment variable\autosilkUtils_public
    After this i loaded script in allegro
    still not able to progress further....
