  3. autosilkUtils.il
  • Replies 38
  • Subscribers 166
  • Views 36205
autosilkUtils.il
FormerMember
FormerMember over 14 years ago
 Hi All:
Hopefully Dave Elder reads this ?
I am running Allegro 16.5  S018 and tried to run the autosilkUtils.il SKILL script.
Everything seems to work except it does not put the DRCs into the walker popup window.
Hopefully someone can fix this ?
This is a great tool
Les
  • DE202408202727
    DE202408202727 over 14 years ago +1
    Hi Les, It should work. What version number does the utility show in the form? Versions after 8.23 are suitable for 16.5 although my latest (unreleased version is 11.04) Dave
  • FormerMember
    FormerMember over 14 years ago +1
    8.12
  • FormerMember
    8.12 from Allegro SKILL Code Library
  • DE202408202727
    DE202408202727 over 13 years ago
    The allegor_site variable is a Windows environment variable. You might like to refer to your Cadence installation notes.
  • giriprasad v
    giriprasad v over 13 years ago
    hi,
    what command should type in command line like ....autosilkutils.....
  • DE202408202727
    silkutils
  • EvanShultz
    EvanShultz over 13 years ago
    Dave, which version is the latest and should be used with 16.6? The 16.5 version above is just a CXT file so I can't see a changelog/header. Thanks for your hard work in, and support of, this community!
  • DE202408202727
    Hi Evan,
    See the attached 16.6 context file for version 12.11.
    Cheers,
    Dave
    AutosilkUtils_public.16.6.zip
