  3. Search files inside sub directories
  • Subscribers 163
  • Views 16566
pcbnagaraj
pcbnagaraj over 14 years ago
Dear All,
Is there a way to search all *.dra files in the sub directories?
The below will list the dra in the root path but I need to get all dra files in the sub directories as well.
dra_list =  setof(file, getDirFiles(dra_path), cadddr(axlDMFileParts(file)) == "dra")
any suggestion is appreciated
Nagaraj.
  • Randy R
    Randy R over 14 years ago +1
    You could have the Operating System create a list of filenames in a file then read that file. For a Windows system: system("dir *.brd /b/s >dir_list.txt") Hope this helps.
  • pcbnagaraj
    Any suggestion??
    Nagaraj.
  • Randy R
    Hope this helps.
  • DE202408202727
    DE202408202727 over 14 years ago
    defun( DE_GetSubDirFiles (dir, fileNameOrTypeOnly @optional keepFileListing, "ttg")
     let((fileName, fileType, listingFile, p, ln, filePath, files)
    rexCompile("/")
    dir = rexReplace(dir, "\\\\", 0)
    fileName = if(index(fileNameOrTypeOnly, ".") then fileNameOrTypeOnly else strcat("*.", fileNameOrTypeOnly))
    fileType = lastelem(parseString(fileName, "."))
    sprintf(listingFile, "%s\\%s_files.listing", getShellEnvVar("TEMP"), fileType)
    when(zerop(system(sprintf(nil, "dir %s\\%s /s/b/-d > %s", dir, fileName, listingFile)))
    p = infile(listingFile)
    while(gets(ln, p)
    filePath = substring(ln, 1, strlen(ln) - 1)
    when(lastelem(parseString(filePath, ".")) == fileType, files = cons(axlOSSlash(filePath), files))
    close(p)
    and(!keepFileListing, isFile(listingFile), deleteFile(listingFile))
    files
    ; draFiles = DE_GetSubDirFiles("L:/library/build/development/allegro/symbols/package", "dra")
