  3. Soldermask Check
  • Subscribers 163
  • Views 18220
Soldermask Check
VijiBala
VijiBala over 14 years ago
I want to check whether the soldermask is provided for all the pads in the design. Is there a way to do this check automatically? Does anybody have the skill file to check the soldermask in the design?
It will be more appreciated if someone shares their thought.
Thanks in advance,
Viji
  • lcanx2
    lcanx2 over 14 years ago
    For Solderpaste as well as Soldermask...
    I'm sure other routines exist that are written far more effeciently, as a SKILL novice I came up with this.
    Not fancy, but acomplishes what I believe you are looking for, and in 16.5.
    cut&paste from here.
    Bill.Munroe@Verizon.net
    PCB Editor 16.2 1.0 Initial              April 2010
    PCB Editor 16.3 1.1 Enhancement for through hole devices.  Group error types in log file.    March 2011
    Intended to Report Design Component Reference Designators and XY coordinates once their Soldermask and Solderpaste
    Pads have been analyzed and determined to not exist.
    Benefits: Reduce ODB++ creation cycles by catching issues earlier in the design flow as
    well as reducing time spent with the AutoSilk checking tools.  As of this writing, Pad Designer will; produce a warning for missing    Mask pads for Intrusives but will not generate a warning when Mask and Paste
    pads are missing from SMD padstack definitions.
    Limitations.. SMD pads cleared using Gang Mask on the Soldermask layers and Design level/Package Geometry; level Pastemask openings, often used for Heat slugs, are currently unsupported, these still require visual checking.; Intrusive Reflow pads (Intrusives requiring paste in-hole for assembly) are not used in our Assembly
    Process and that condition is deemed an error and passed to the log file.
    Pad SIZE checking is NOT done by this tool.
    Invoked with "mppads".
    axlCmdRegister( "mppads" `mask_paste)
    defun( mask_paste ()
    ; selects TOP and BOTTOM pins.
    axlClearSelSet()
    vis_list = axlVisibleGet()
    axlVisibleDesign(nil)
    axlVisibleLayer("PIN/TOP" t)
    axlSetFindFilter(?enabled list("noall" "pins")
            ?onButtons list("noall" "pins"))
    axlAddSelectAll()
    pp_top_list = axlGetSelSet()
    axlClearSelSet()
    axlVisibleLayer("PIN/BOTTOM" t)
    axlAddSelectAll()
    pp_bottom_list = axlGetSelSet()
    axlVisibleSet(vis_list)
    ;setup for pad counts to be reported
    smdcount=0
    intcount=0
    badcount=0
    ;printing to the log and prepare to put results to screen
    axlDebug(t) ;debug on debug off->;axlDebug(nil)
    logfile = outfile("mask_paste.log")
     fprintf(logfile "         Verify Gang Mask Visually.\n")
    close(logfile)
    ; append to the log file
    logfile = outfile("mask_paste.log" "a")
    fprintf(logfile "\n    SMD's with Primary Mask Pads Missing\n\n")
    ;Get the name and XY location of the Padstacks and prepare to write it to the log if a problem is found.
    foreach(pp_top_db pp_top_list
    stack_dbid = pp_top_db->parent
    stack_name = axlDbidName(stack_dbid)
    location = stack_dbid->xy
    ts_pad = axlDBGetPad(pp_top_db "pin/soldermask_top" "regular")
    top_mask = ts_pad-> figureName
    tp_pad = axlDBGetPad(pp_top_db "pin/pastemask_top" "regular")
    top_paste = tp_pad-> figureName
     if(!(pp_top_db->isThrough) then
      pin_type = "SMD"
        smdcount++
       else
      pin_type = "INT"
        intcount++
     ) ;endif
    if((pin_type == "SMD") then
     if(top_mask == "NULL" then
      fprintf(logfile "\n %L, %L\n\n" stack_name location)
     ) ;endif
    ) ;endif
    ) ;end foreach
    ;Now select Pins for analyzing SMD Bottom pads.
    axlClearSelSet()
    axlAddSelectAll()
    axlClearSelSet()
    axlAddSelectAll()
    smdcount=0
    intcount=0
    badcount=0
    fprintf(logfile "\n    SMD's with Secondary Mask Pads Missing\n\n")
    foreach(pp_top_db pp_bottom_list
    ts_pad = axlDBGetPad(pp_top_db "pin/soldermask_bottom" "regular")
    bot_mask = ts_pad-> figureName
    tp_pad = axlDBGetPad(pp_top_db "pin/pastemask_bottom" "regular")
      pin_type = "SMD"
        smdcount++
       else
      pin_type = "INT"
        intcount++
     ) ;endif
     if(bot_mask == "NULL" then
     ) ;endif
    ) ;endif
    ) ;end foreach
    axlClearSelSet()
    axlAddSelectAll()
    axlClearSelSet()
    axlAddSelectAll()
    smdcount=0
    intcount=0
    badcount=0
    fprintf(logfile "\n  SMD's with Primary Paste Pads Missing\n\n")
      pin_type = "SMD"
        smdcount++
       else
      pin_type = "INT"
        intcount++
     ) ;endif
     if(top_paste == "NULL" then
     ) ;endif
    ) ;endif
    ) ;end foreach
    axlClearSelSet()
    axlAddSelectAll()
    axlClearSelSet()
    axlAddSelectAll()
    smdcount=0
    intcount=0
    badcount=0
    fprintf(logfile "\n  SMD's with Secondary Paste Pads Missing\n\n")
    bot_paste = tp_pad-> figureName
      pin_type = "SMD"
        smdcount++
       else
      pin_type = "INT"
        intcount++
     ) ;endif
     if(bot_paste == "NULL" then
     ) ;endif
    ) ;endif
    ) ;end foreach
    ; Now select Pins for analyzing Through hole TOP pads.
    axlClearSelSet()
    axlAddSelectAll()
    axlClearSelSet()
    axlAddSelectAll()
    ;reset pad counts
    smdcount=0
    intcount=0
    badcount=0
    ;Intrusives Missing Mask Check.
    fprintf(logfile "\n  Through Hole with Primary Mask Pads Missing\n\n")
      pin_type = "SMD"
        smdcount++
       else
      pin_type = "INT"
        intcount++
     ) ;endif
    if((pin_type == "INT") then
     ) ;endif
    ) ;endif
    ) ;end foreach
    ; Now select Pins for analyzing Through hole BOTTOM pads.
    axlClearSelSet()
    axlAddSelectAll()
    axlClearSelSet()
    axlAddSelectAll()
    ;reset pad counts
    smdcount=0
    intcount=0
    badcount=0
    fprintf(logfile "\n  Through Hole with Secondary Mask Pads Missing\n\n")
      pin_type = "SMD"
        smdcount++
       else
      pin_type = "INT"
        intcount++
     ) ;endif
     ) ;endif
    ) ;endif
    ) ;end foreach
    ; Now select Pins for analyzing Through Paste Pads- Top side.
    axlClearSelSet()
    axlAddSelectAll()
    axlClearSelSet()
    axlAddSelectAll()
    ;reset pad counts
    smdcount=0
    intcount=0
    badcount=0
    fprintf(logfile "\n  Through Hole WITH Primary Paste Pads\n\n")
      pin_type = "SMD"
        smdcount++
       else
      pin_type = "INT"
        intcount++
     ) ;endif
     if(top_paste != "NULL" then
     ) ;endif
    ) ;endif
    ) ;end foreach
    ; Now select Pins for analyzing Through hole Paste pads - BOTTOM.
    axlClearSelSet()
    axlAddSelectAll()
    axlClearSelSet()
    axlAddSelectAll()
    ;reset pad counts
    smdcount=0
    intcount=0
    badcount=0
    fprintf(logfile "\n  Through Hole WITH Secondary Paste Pads\n\n")
      pin_type = "SMD"
        smdcount++
       else
      pin_type = "INT"
        intcount++
     ) ;endif
     if(bot_paste != "NULL" then
     ) ;endif
    ) ;endif
    ) ;end foreach
    ; Close the Log file then display to the screen
    close(logfile)
    logWindow = axlUIViewFileCreate("mask_paste.log" "            Missing Mask & Paste Pads Report" nil '(44 44) )
  • VijiBala
    Hi lcanx2,
    Thank you for your reply.
     I run the SKILL as stated in the file, but it gives me an error "Can't open file: */mask_paste.log".
    I think this SKILL file is to chek whether the soldermask & pastemask is present for the pad or not. But what I am looking for is to check the presence of the soldermask & also to check if the soldermask provided is "x" times more than the regular pad.
    Please help me.
    Thanks in advance,
    Viji
  • Gowtham229
    Gowtham229 over 7 years ago in reply to VijiBala
    hi
    why this code runs with below error these days
    E- *Error* fprintf: argument #1 should be an I/O port (type template = "ptg") - nil
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    the code works correctly for me in 16.6 & 17.2:
    \t (00:00:01) allegro 17.2 S059 Windows SPB 64-bit Edition
    \t (00:00:01) Journal start - Tue Sep 24 06:21:25 2019
    \t (00:00:01) Host=ASUS-LAPTOP User=davidh Pid=14600 CPUs=8
    \t (00:00:01) CmdLine= allegro
    \t (00:00:01)
    (00:00:01) Loading axlcore.cxt
    \t (00:00:03) Opening existing design...
    \d (00:00:03) Design opened: D:/XXXXX.brd
    \i (00:00:03) trapsize 444
    \i (00:00:03) trapsize 458
    \i (00:00:03) trapsize 369
    \i (00:00:03) trapsize 379
    \i (00:00:04) generaledit
    \i (00:00:09) skill '`'(load "c:/users/davidh/documents/mask_test.ils")`''
    (00:00:09) t
    \i (00:00:15) mppads
    \i (00:00:15) setwindow text
    \i (00:00:15) stick
    \i (00:00:15) generaledit
    \i (00:00:19) setwindow text
    \i (00:00:19) close
    \i (00:00:23) exit
    \t (00:00:23) Journal end - Tue Sep 24 06:21:47 2019
  • Gowtham229
    Gowtham229 over 7 years ago in reply to DavidJHutchins
    yes you are right the code is working but it was not finding soldermask missing for through hole pins i'm trying to check the code to implement the soldermask missing check for through hole as well.pls share if any one has already implemented it
