  3. Is it possible to pass variables to script from inside SKILL...
  • Views 16697
Is it possible to pass variables to script from inside SKILL function
Kadar
Kadar over 14 years ago
Hello everybody,
Is it possible to pass variables to script from inside SKILL function,
And then replay the script??
EVGY
  • Pawandeep
    Pawandeep over 14 years ago
    You can use the output of function axlUIPrompt to store in your variable.
    Pawan
  • Kadar
    Hi Pawan,
    I want to record script and then replay it but with another value.
    For example i want to export DXF file so i go to : File -> Script -> Record
    I record the script filling the form window with name "First".
    Now i want to export DXF file named "Second" using the same script,
    So i want the name  "Second" to be filled instead of "First".
    Is it possible to do so?
    BR,
    EVGY
  • Pawandeep
    You should consider generating dxf using your recorded script with a temporary file name and then renaming this file using your skill(both task performed in a single SKILL code).
    For renaming a file there is a function available
    renameFile( "old" "new" )
    Pawan
  • fxffxf
    fxffxf over 14 years ago
    You can utilize Allegro variable substitution.
    - Record a starting script
    - edit the file to add variable substitutioncapability
    Example if you want dxf output file to be variable in your just recorded script you will see a line the script like:
       FORM dxf_out dxffile foo
    Change this to take advantage of variable substitution:
       FORM dxf_out dxffile $mydxfile
     Now you can either call this script from another script or take advantage of command chaining to set the variable
    "set mydxffile foo; replay myscript"
    If you worry about the script being called without the variable being set add before the variable an ifnvar line  to defauly the variable to a default value:
      ifnvar  mydxfile "set mydxfile foo"
  • Kadar
     You've understood my question in exact way!!!
    Crystal clear answer!!!!
    Huge thank YOU !!!
    BR,
    EVGY
