  3. Calling script inside skill gives error E- Form field label...
  • Subscribers 163
  • Views 3385
Calling script inside skill gives error E- Form field label not found
pcbnagaraj
pcbnagaraj over 14 years ago
Dear All,
I am using the axlShell command to execute allegro command to dehilight all elements.
when I run the skill from the SKILL prompt it works but when I run from Allegro command prompt it give me the below error
Below is the command issues to allegro to dehilight all elements inside allegro.
axlShell("dehilight ;setwindow form.find;FORM find all_on  ;setwindow form.mini;FORM mini dhlt_all  ;setwindow pcb;prepopup 0 0;done ")
Thanks for your suggestions!!
Nagaraj.
  • Pawandeep
    Pawandeep over 14 years ago
    Hi Nagaraj,
    Have you tried using axlClearSelSet() instead?
    Pawan
  • pcbnagaraj
    axlClearSelSet() will remove the dbids selected using Find filter.
    But I am trying to dehighlight all elements which are highlighted using ‘Assign Color’
    Nagaraj.
  • Pawandeep
    Hi Nagaraj,
    What about axlDehighlightObject(List of highlighted dbids)?
    Pawan
  • pcbnagaraj
    It worked thanks.
    Nagaraj.
