  3. Drill table modification and new data column adding
  • Views 15151
Kadar
Kadar over 14 years ago
Hi All,
Is it possible to create drill tables with extra column that will
Contain DATA I want  i.e.:
FIGURE  | SIZE      |QTY   | TOLERANCE  |  PLATED    |  SIZE*scailing factor(=2)|
  •         8.0        194         +2.0/-3.0       PLATED           16
  •         9.0        10           +2.0/-3.0       PLATED           18
Thanks to All in advance!!
  • oldmouldy
    oldmouldy over 14 years ago
    Take a look at the DLT file(s), share\pcb\text\nclegend directory of the installation, the documentation is within the files, take a copy of a file and change the contents to see if you can get what you need, otherwise, you probably need to get involved in SKILL programming...
