  3. is there a skill code to check .dra or .brd for missing...
  • Views 14920
is there a skill code to check .dra or .brd for missing info?
treobum
treobum over 14 years ago
Is there an existing skill code that can check a .dra or .brd for missing info in a symbol or all symbols? For example if its missing max height property or missing a dfa_bound_top shape or any other element that you want checked.
If there is no existing skill code or way to do this in allegro who wants to try and have a go at it?
 Thank you - Gino
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    I'm not aware of such a program, but if you use the batch processing method that I've described in the thread below then you can write a skill program that checks for the info you're looking for /forums/T/22844.aspx
    pseudo skill code could be something like
    open report file, write dra name to report
    get all shapes
    check if one of them is dfa_bound_top, if not write message to report
    check if place_bound_top has height property, if not write message to report
    close report
    Another approach could be to create a skill program that runs through all symbols that can be seen from the psm path and do the same as outlined above.
    Best regards
    Ole
  • treobum
    Thanks Ole. I will give your recommendations a try.
