  3. Generate External DRC
  • Views 15639
comet
comet over 14 years ago
Hey,
I saw a post recently regarding the skill command on generating external DRC, "axlDBCreateExternalDRC"... where could I get this?
 Thanks!
  • Pawandeep
    Pawandeep over 14 years ago
    There is one code from Dave that uses this function
    /forums/T/22199.aspx
    Pawan
  • comet
    comet over 13 years ago
    Hey, this is not what i'm looking for. Thanks anyway.
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    Can you then elaborate on what it is that you're looking for?
    The description for the command can be found in the online help and the previous answer gave an example that utilizes external DRC creation.
    Best regards
    Ole
  • comet
    Hey Ole,
    Yeah, I had an old ver. Now, this autosilkUtils_public.il solved one of the issue of checking silkscreen to soldermask spacing. Thanks.
    Now, I'm looking for how to check the spacing between two soldermasks (soldermask-to-soldermask DRC) ?...
    Appreciate the help guys!
