  3. Adding a new menu item to Allegro PCB Editor
  • Replies 26
  • Subscribers 169
  • Views 36550
chads108
chads108 over 14 years ago
 I want to add, or really append, a new menu item to the Allgro PCB Editor menu.  What is the easiest way to handle this without having to modify the installed menu?  Maybe someone has an example that I could follow?
  • chads108
    chads108 over 14 years ago +1
    Is there a way to handle more than one "popup" in the dynamic menu? I have this text in the SKILL file: ; Create Symbol Editor Menu Entries; SymToolsMenu = '( (popup "Text") ("Change Textsize..." "replay…
  • craigtone
    craigtone over 9 years ago +1
    Sorry to dig up old threads but I was searching for the same submenu answer as Chad. I found the solution is to end the submenu by adding a line "(end)" after the submenu.
  • chads108
    Well, I went to lunch and when I came back the answer was sitting right in front of me.  Guess I just needed to get up and take a break.
    Chad
  • tonyhuffman
    tonyhuffman over 12 years ago
    I tried to modify my custom menu to display different items (basically take away a lot of menu items for Library use) and I am not getting it to work for me. Can someone help me to get this to work?
     The menu item displays but is greyed out and not able to be used. I obviously got something wrong but not able to pinpoint it. I have the file attached.
    MTC_SiP.il
  • tonyhuffman
    Put this to the side for a while and just came back to it. I still can not figure out what I am doing wrong.
     Help would be appreciated.
  • oldmouldy
    oldmouldy over 12 years ago
    The "res=" statements have "won" a "q" variable from somewhere, I would have expected to get "q unbound variable" in the command window when the script is run. I think that the "q" should be the "m1" for your menu, that may fix it. Otherwise, cut the menus down to single entries for each menu / sub-menu, get that working and then apply those priciples to get all the menus / sub-menus working.
  • girish
    girish over 12 years ago
    Dear Mike &  Chad
    This is very good thread  for creating customized menu.I followed the instructions given here & it’s working fine !!!!!!Thanks guys.Previously I used separate skill loading based on their function  by calling them in  Allegro. Men & packages_symbol.men Now its single menu file , how to make it two different one for symbol & one for board .I saw there is one attachment in this thread but not possible to open (Please zip & attach)
    Best Regards
    Girish Kumar
