  3. Adding a new menu item to Allegro PCB Editor
  • Replies 26
  • Subscribers 169
  • Views 36561
chads108
chads108 over 14 years ago
 I want to add, or really append, a new menu item to the Allgro PCB Editor menu.  What is the easiest way to handle this without having to modify the installed menu?  Maybe someone has an example that I could follow?
  • chads108
    chads108 over 14 years ago +1
    Is there a way to handle more than one "popup" in the dynamic menu? I have this text in the SKILL file: ; Create Symbol Editor Menu Entries; SymToolsMenu = '( (popup "Text") ("Change Textsize..." "replay…
  • craigtone
    craigtone over 9 years ago +1
    Sorry to dig up old threads but I was searching for the same submenu answer as Chad. I found the solution is to end the submenu by adding a line "(end)" after the submenu.
  • mrigashira
    mrigashira over 6 years ago
    Here is a blog post by Tyler Lockman that anyone looking to customize menus and toolbars will find useful - BoardSurfers: Make Menus Your Own – Customizing Menus and Toolbars with Things You Use Daily. To quote from the post "You can add as many custom commands, toolbar buttons, and menu item entries as you like to the tool. Using SKILL to add them will make sure that they are available in whatever release of Allegro layout editor you’re working with, and only the product options and design types that make sense for the command. "
