  3. How to capture minimum spacing?
  • Views 15852
dgstan
dgstan over 14 years ago
I need to find the absolute minimum spacing defined in the Constraint Manager. This includes the CSets and any number manually entered in the CM, Region rules, Class/Class, etc.
I see the function axlCNSGetSpacing will retrieve the values of your various CSets, but smaller numbers can be manually entered (i.e. not defined by a CSet) or set manually under region or class/class rules. Is there a way to derive this rock-bottom spacing value?
I tried to get that info via axlCnsTableSeek, but it doesn't seem to work period.
Thanks in advance,
Douglas Stanley
  • DE202408202727
    DE202408202727 over 14 years ago
    Hi Douglas,
    I achieve this by exporting a tech file,  parsing each section (using share\pcb\xml-formats\techfile.dtd) and analysing the results to find the minimum values. I would be interested if you find a more efficient method.
    Contact me off line if you want to share code.
    Cheers, Dave
  • Helen
    Helen over 14 years ago
    I have some primitive code I did in 2008 to find space less then min.
    axlCmdRegister("L2L" 'L2L)
    (defun L2L ()
    ; find line2line less then 0.075mm
    ;get all nets
    net_list = axlSelectByName("NET" "*" t)
    net = car(net_list)
    foreach(net net_list
      L_L = net->prop->"LINE_TO_LINE_SPACING"
      if(L_L !=nil  then
         value = atof(L_L)
         if(value < 0.075 then
       printf("%s %s\t%s\t%s\n" "DRC value is :" L_L "  NET:" net->name)
    );end for each
    ; for spacing Csets
    scset_list = axlCnsList('spacing)
    scset=car(scset_list)
    layer_list = axlGetParam("paramLayerGroup:etch")->groupMembers
    layer = car(layer_list)
    foreach(layer layer_list
          foreach(scset scset_list
                 L_L_set = axlCNSGetSpacing(scset layer 'line_line)
                 if(L_L_set !=nil  then
                     if(L_L_set < 0.075 then
                     printf("%s %.3f\t%s\t%s\t%s\n" "DRC value is :" L_L_set "SCSet name:" scset layer)
                ) ; end foreach
        ); end foreach
    axlClearSelSet()
    );end defun
