  3. How to use axlAirGap() to get minimum spacing between two...
  • Subscribers 163
  • Views 15859
How to use axlAirGap() to get minimum spacing between two cline segments
Bessy
Bessy over 14 years ago
Hi Sir,
 I want to get the minimum spacing between two clinesegs(line to line or arc to arc), which were in different layers, such as one segment was in ETCH/layer_3 and the other was in ETCH/layer4. When I used the command axlAirGap(), sometimes it could return the airgap data, but sometimes it returned nil.
Bessy
  • fxffxf
    fxffxf over 14 years ago
    Given 2 cline seg dbids (obj1 and obj2) do: axlAirGap(obj1 obj2 nil 'anyLayer)
    The default for axlAirGap is same layer measurement.
  • Bessy
    Very good, it works well,
    Thank you very much
