  3. Autorun function on Allegro start
  • Views 16226
Kadar
Kadar over 14 years ago
Hi All,
Can somone explain to me how can I run my SKILL function on Allegro PCB
On tool start up. Calling the function from allegro.ilinit can't be performed.
Thank You in advance,
Kadar
  • DE202408202727
    DE202408202727 over 14 years ago
    You will have to be a bit more specific.
    allegro.ilinit should run if it's in the correct path. Check your ALLEGRO_SITE environment variable.
    Dave
  • Kadar
    Hi Dave,
    Thank You for reply.
    My "ALLEGRO_SITE" variable defined correctly - all my functions are loaded from inside "ALLEGRO_SITE/skill/allegro.ilinit".
    I wrote the next lines in "ALLEGRO_SITE/skill/allegro.ilinit.
    load("ALLEGRO_SITE/skill/My_Func_file.il")
    axlCmdRegister("CMD_Name" 'Func_Name ?cmdType "general")
    To autorun the function I added (In the End of allegro.ilinit)
     CMD_Name (or Func_Name() ):
     But it caused the tool to fail on startup. What is done wrong?
    Kadar
  • DE202408202727
    This is an example of what your ilinit file should contain:
    axlCmdRegister("tidy folder" 'tidyFolder ?cmdType "general")
    tidyFolder.autoload = "tidyFolder.il"
    To run this routine I need to type tidy folder in the console window.
    If you want a routine to run every time you start Allegro you should look at the axlTriggerSet command. This is a command that I have in our ilinit file:
    axlTriggerSet('open 'tait_OpenAllegroTrigger)
    tait_OpenAllegroTrigger is a Skill function.
    Dave
  • Kadar
    Hello Dave,
    After some code changes and using "axlTriggerSet" function
    My function runs on tool statup.
    THANK YOU!!!!!!
