  3. Getting file name from a port
  • Subscribers 163
  • Views 15347
Pawandeep
Pawandeep over 14 years ago
Is there any function for getting the file name of a port?
Say if I want to get the “test.xls” from the below port.
inPort = infile(“C:\test\test.xls”)
Pawan
  • DE202408202727
    DE202408202727 over 14 years ago
    get_filename(inPort)
  • Tyler
    Tyler over 14 years ago
    You can use get_filename(<port>) to get the full path for the port as a string. This can be passed to axlDMFileParts() to get the different portions, such as the directory, file name, file name with extension, or just file extension. Since you seem to want the file with extension, you would want the third element in the list returned from axlDMFileParts().
    - Tyler
  • Pawandeep
    Hi Tyler/Dave,
    Below works very well.
    axlDMFileParts(get_filename(inPort))
    Pawan
