  3. Angle between two segments
  • Views 15270
luanvn81
luanvn81 over 14 years ago
 Hi all !
My code to check if an angle betwween two segments is 90 degrees or not. here it is :
first_seg = car(cline_seg)
second_seg = nthelem(2,cline_seg)
x11=caar(first_seg->startEnd)
y11=cadar(first_seg->startEnd)
x12=car(lastelem(first_seg->startEnd))
y12=lastelem(lastelem(first_seg->startEnd))
x21=caar(second_seg->startEnd)
y21=cadar(second_seg->startEnd)
x22=car(lastelem(second_seg->startEnd))
y22=lastelem(lastelem(second_seg->startEnd))
a = axlDistance(x11:y11, x12:y12)
b = axlDistance(x21:y21, x22:y22)
c = axlDistance(x11:y11, x22:y22)
if(c*c == (a*a + b*b) then
fprintf(writeOutFile, "Location (%L %L)\n", x12,y12)
);end if
   the result are:   " E- *Error* range: argument #1 should be a number (type template = "n") - nil  ". I think axlDistance command have got error,  but only command  a = axlDistance(x11:y11, x12:y12) is OK. How can I fix it? Please help me.
PS:  x11,y11 --------------------x12,y12                    x21,y21--------------------x22,y22
 (x11, y11) (x12,y12) =  (-19885.0 26245.0) (-19885.0 26400.0)
 (x21, y21) (x22,y22) =  (-19885.0 26400.0) (-19985.0 26500.0)
  • knuhcrek
    knuhcrek over 14 years ago
    why use axlDistance at all?  Use the dot product. If the dot product of the two segments equals zero then the segments are at right-angles to each other.
    procedure( calcDotProduct( ptA ptB ptC ptD)
    prog(( dot_product)
    dot_product = 0.0  ; cosine of angle between segments -- segs are perpendicular when == 0
    ptA.x = xCoord( ptA)
    ptA.y = yCoord( ptA)
    ptB.x = xCoord( ptB)
    ptB.y = yCoord( ptB)
    ptC.x = xCoord( ptC)
    ptC.y = yCoord( ptC)
    ptD.x = xCoord( ptD)
    ptD.y = yCoord( ptD)
    ;rintf("ptA.x= %n  ptA.y= %n  ptB.x= %n  ptB.y= %n\n", ptA.x ptA.y ptB.x ptB.y)
    ;rintf("ptC.x= %n  ptC.y= %n  ptD.x= %n  ptD.y= %n\n", ptC.x ptC.y ptD.x ptD.y)
    dot_product = (ptB.y - ptA.y)*(ptD.y - ptC.y) + (ptB.x - ptA.x)*(ptD.x - ptC.x)
    ;rintf("dot product= %1.6f\n", dot_product)
    return( dot_product)
    );end-prog
    );end-procedure
    HTH,
    Chris Walters
    rusty former Cadence guru
  • luanvn81
     Hi Chris!
       Your code really help me so much, my skill now works OK. thank you very much.
    Luan.
