  3. axlCustomColorObject arguments
  • Subscribers 159
  • Views 14193
Pawandeep
Pawandeep over 13 years ago
What does [g_custom_color] argument means in axlCustomColorObject and how can I find this number for a particular color?
Is there any limit<size> for this argument?
Pawan
  • eDave
    eDave over 13 years ago
    Hi Pawan,
    Read the documentation for axlColorSet and axlColorGet. I think the current limit is 192.
    Dave
  • Pawandeep
    Hi Dave,
    Thanks.
    Is there any function to set the color for a dbid by passing directly RGB value (eg 255 255 255) instead of using index of color palette?
    Pawan
  • Ejlersen
    Ejlersen over 13 years ago
    Hi Pawan
    I've not been able to find such a method.
    What I've found is that you set the color palette indexes and can then use axlColorSet to set indexes using RGB values
    Only exception seems to be background color which can be set individually using rgb values.
    regards
    Ole
  • eDave
    What he said!
  • Pawandeep
    I raised a CCR 1074136 (Setting color on dbid's based on RGB value) for the same if someone else also wish to follow up on the same.
    Pawan
