  3. generic questions on paths and objects they connect
  • Views 13651
knuhcrek
knuhcrek over 14 years ago
 Question: is it valid to assume a path object will have these characteristics?
1.  path can connect to at most two non-path objects? Is there a case where a path could connect to three non-path objects?
2. path can ONLY connect to the following non-path objects:
    pin  via  shape tee shape
   Are there other non-path objects that a path can connect to?
3. What would be some ways to determine what non-path object is connected to a given endpoint of a path object? A simplistic approach would be to compare the ->xy of the endpoint with those non-path objects on the same branch - are there better ways?
Chris Walters
rusty former Cadence guru
