  3. PCB Skill variable saved to Windows clipboard
  • Views 15929
labGeoff
labGeoff over 14 years ago
I am currently running Allegro on a windows 7 machine.  Does anyone know of a way to save a skill variable to the windows clipboard?  thanks!
  • Brian Collins
    Brian Collins over 13 years ago
     First you will need a Windows program that takes a string and puts it into the Windows clipboard. You could write one yourself or use an existing one such as: clip.exe that comes with Windows Server 2003or nircmd.exe.
    I chose the clip.exe method. I downloaded clip.exe and put it in the C:\windows directory, but anywhere in the path would probably work. Attached is a skill file that does what you require. The checking is not very good, but perhaps one of the skill gurus on this forum can fix that up. I have tried this on Windows XP SP3, but not on Win 7.
     /* envvar2clp.il - writes an environment variable to the Windows clipboard
       Written by: Brian Collins 2012 11 23
       You need to download the "clip.exe" file from Win Server 2K3 and put it in C:\windows
    axlCmdRegister( "envvar2clp" 'envvar2clp )
    defun( envvar2clp ( var_Name )
    var_Text = axlGetVariable( var_Name )
    if(var_Text == nil then
       sprintf(err_Msg "%s env var does not exist!" var_Name)
       axlUIConfirm(err_Msg)
    else
       sprintf( var_FileName "tmp_%s.txt" var_Name)
       var_Port = axlDMOpenFile( "temp" var_FileName "w" )
       fprintf( var_Port "%s\n" var_Text )
       axlDMClose(var_Port)
       sys_CallString=strcat("clip " "< " var_FileName) ;<- This assumes that you have the "clip.exe" file in the path.
       result_SystemCall=system(sys_CallString)
       deleteFile(var_FileName)
       ) ;end if
    ) ; end defun envvar2clp
  • DE202408202727
    DE202408202727 over 13 years ago
    That's a great find!
    In Windows 7 clip.exe is already there so no download is needed.
    You can try this slightly simpler code:
    if(axlGetVariable(var_Name)
    then system(sprintf(nil, "echo %%%s%% | clip", var_Name))
    else axlUIConfirm(sprintf(nil "%s env var does not exist!", var_Name))
    ) ;end if
  • Brian Collins
     Thanks eDave! I don't do enough coding to be elegant...
     Brian
  • labGeoff
    labGeoff over 13 years ago
    Thanks all!  Works great!
    Geoff Roth
