  3. Detect interception between line and arc or arc and arc
  • Views 19999
SkilSiao
SkilSiao over 14 years ago
Hi All,
is there a function to detect any intersection between straight line and arc?
Given that both of the objects are Lines...
the axl_ol_ol2 function is able to detect straight line and straight line intersection only.
  • knuhcrek
    knuhcrek over 14 years ago
    That function merely fixes axl_ol_ol, as you have found. What is needed is more robust function that can compare any two segments and return nil (if there is no intersection) or a list of intersection points, after you screened out the special cases where the lines or arcs are identical. Should easily be handled by basic trigonometry  and some equation-solving.
    line-line  --  nil or 1 intersection point
    line-arc   --  nil or 1 or 2 i-points
    arc-line   --  nil or 1 or 2 i-points
    arc-arc    --  nil or 1 or 2  i-points
    Chris Walters
    rusty former Cadence guru
  • SkilSiao
    Hi Christ,
    Thanks for the suggestion.
    It seems like no existing function can achieve that and we need to write our own.
    one of the algo i am thinking of is like this:
    break the arcs into multiple (i) segments, then write a for i loop to:
    1. get the start and end point of each segment.
    2. use axl_ol_ol2 to get the intersection point and distance with the line or another arc's line segment.
    3. store the interception points or distances (if no intersection).
    after the for loop, we can have the intersection points or min distance.
    larger the i, more accurate the result.
  • fxffxf
    fxffxf over 14 years ago
    If both objects are dbids then try axlAirGap; the 'enhanced option should provide additional info.
  • DE202408202727
    DE202408202727 over 14 years ago
    See attached.
    DEFn_arcLineSegmentIntersections - find the intersection points between an arc and a line segment
    DEFn_arcArcIntersections - find the intersection points of two arcs
    DEFn_circleLineIntersections - find the intersection points of an circle and a line
    DEFn_circleCircleIntersections - find the intersection points of two circles
    DE_arcIntersections.zip
  • SkilSiao
    Hi eDave, Thank you very much. (I haven't tried out though)
    you have always been very helpful.  =)
    Hi fxffxf, axlAirGap does NOT support lines dbid and always returns nil
    you may want to tried out, assume aa and bb are two dbids of Lines on Etch/Surface,
    Skill>axlAirGap(aa bb nil 'enhanced)
    nil
