  3. help on shape fill when using axlDBCreateShape..
  • Replies 16
  • Subscribers 163
  • Views 25425
D912349
D912349 over 13 years ago
Hi everyone,
 I am currently working on a certain program wherein a certain cline segment will be converted to shape(version of allegro used is 16.5).. i was able to generate the shape by first getting the polygon object of the cline then use it on axlDBCreateShape.. refer to code below..
clineDbid = (dbid of cline to converted to shape)
polyDbid = car(axlPolyFromDB(clineDbid ?endCapType 'SQUARE))
axlDBCreateShape(polyDbid t layer netName)
The program works fine but the main problem is the shape fill type. As default, solid fill shape or dynamic copper type should be generated but whenever i run the program, static crosshatch type is generated.. I need the shapes generated to be in solid fill shape/dynamic type..
Thanks..
  • DE202408202727
    DE202408202727 over 13 years ago
    Check your shape_add_filltype setting
  • D912349
    shape add setting is already set to dynamic but still the output remain the same.. is there a way to return user preferences set up back to default setting?. This may help test the routine if user preferences affects the output of the axl function..
  • D912349
    i also tried running your skill code. It works fine but the problem on shape fill is not yet solved
  • DE202408202727
    Try exiting Allegro and renaming your HOME folder before trying again.
  • D912349
    thanks for the suggestion Dave, I also tried that but output generated is still the same.. shape fill is still static cross hatch,,
