  3. help on shape fill when using axlDBCreateShape..
  • Replies 16
  • Subscribers 163
  • Views 25430
D912349
D912349 over 13 years ago
Hi everyone,
 I am currently working on a certain program wherein a certain cline segment will be converted to shape(version of allegro used is 16.5).. i was able to generate the shape by first getting the polygon object of the cline then use it on axlDBCreateShape.. refer to code below..
clineDbid = (dbid of cline to converted to shape)
polyDbid = car(axlPolyFromDB(clineDbid ?endCapType 'SQUARE))
axlDBCreateShape(polyDbid t layer netName)
The program works fine but the main problem is the shape fill type. As default, solid fill shape or dynamic copper type should be generated but whenever i run the program, static crosshatch type is generated.. I need the shapes generated to be in solid fill shape/dynamic type..
Thanks..
  • DE202408202727
    DE202408202727 over 13 years ago
    Sorry, I'm running out of ideas.
    Does is happen on every net?
    Does it happen on a brand new design?
    Does it happen if you add a shape manually?
  • D912349
    Yes, it happen on every net even dummy nets, same with design.. i also tried it on other machine but still shows the same output. but when I add the shape manually, dynamic copper type of shape is generated..
    Another thing. is there another way of generating shape without using axlDBCreateShape given that the input data will come from cline object?. or is there a way to change shape type using dbid of a shape?.
  • DE202408202727
    axlDBCreateShape is a wrapper for the two commands: axlDBCreateOpenShape and axlDBCreateCloseShape. You might like to try replacing axlDBCreateShape with these two commands. I don't think there is any other easy way to convert a cline to a shape. Does using a path instead of a polygon make any difference? i.e. rpath = axlPathStart(list(0:0 0:5 5:5 5:0 0:0)), axlDBCreateShape(rpath t "ETCH/TOP" "GND")
  • D912349
    using path might solve the problem but it is difficult to create path from a cline object. because basically, corners of the cline still needs to be solved from width and strartEnd attributes to create a path, considering that clines comes from different angles. Any way, Thanks eDave for the support, I will update whatever I find out regarding this issue..
  • fxffxf
    fxffxf over 13 years ago
    Maybe this is due to the display pattern being selected for shapes. You can verify this be doing a display element on the shape and see what it reports for fill type.
