  3. help on shape fill when using axlDBCreateShape..
  • Replies 16
  • Subscribers 163
  • Views 25437
D912349
D912349 over 13 years ago
Hi everyone,
 I am currently working on a certain program wherein a certain cline segment will be converted to shape(version of allegro used is 16.5).. i was able to generate the shape by first getting the polygon object of the cline then use it on axlDBCreateShape.. refer to code below..
clineDbid = (dbid of cline to converted to shape)
polyDbid = car(axlPolyFromDB(clineDbid ?endCapType 'SQUARE))
axlDBCreateShape(polyDbid t layer netName)
The program works fine but the main problem is the shape fill type. As default, solid fill shape or dynamic copper type should be generated but whenever i run the program, static crosshatch type is generated.. I need the shapes generated to be in solid fill shape/dynamic type..
Thanks..
  • D912349
    Hi fxffxf,
    The main problem in generating the shape is the shape type. Basically, their are 3 options for axlDBCreateShape. solid filled, unfilled and static cross hatch. if you have checked the posted code, it should create a solid type but instead it created a static cross hatch type. So I think it has nothing to do with display pattern..
