  3. String returned from axlDMFileBrowse()
  • Subscribers 159
  • Views 14172
VTAA
VTAA over 13 years ago
 Hi All,
Would you please kindly point out what did I do wrong in few lines of code below?
My objective is to acquire file name of browser, pass it to IDF_IN fuction. My variable
"file_name" is recongized by axlUIViewFileCreate() function but is not recognized
by axlRunBatchDBProgram(....-d PTC) option. How should I handle that variable?
Any effort is much appreciated.
   procedure(view_file()
   let( (emn_file file_name idf_result cur_db)
     file_name = axlDMFileBrowse(nil nil ?optFilters "MCAD file (*.emn)|*.emn")
     axlRunBatchDBProgram("My IDF in" "idf_in -o %s
                                          -d PTC file_name"
                                          ?reloadDB t)
     axlUIViewFileCreate(file_name "My EMN file" nil)
   )) ; end let, end procedure my IDF in
Thanks in advcance,
Vinh Ta
  • eDave
    eDave over 13 years ago
    Try this:
    axlRunBatchDBProgram("My IDF in" sprintf(nil, "idf_in -d PTC %s", file_name) ?reloadDB t)
  • VTAA
    Hi Dave,
    Thank you for the solution, it works!
    Would you please point me to direction how to trap error returned from idf_in?
    Thank you in advance.
    Vinh
  • eDave
    You could try adding the ?logfile option to the axlRunBatchDBProgram command but I don't ever have much success with that.
  • VTAA
    Hi Dave,
    Thank you for the reply.
    Your help is much appreciated.
    Vinh Ta
