  3. axlCNSCreate for Same net constraints
  • Subscribers 163
  • Views 15118
Mstrghettorigg
Mstrghettorigg over 13 years ago
Hi all,
I'm trying to create a same net spacing constraints using axlCNSCreate command, but I only see the option for 'physical, 'spacing, and  'electrical option on algroskill.pdf.
Am I using the wrong command or just not looking at the right document for this?
Any help will be much appreciated.
  • oldmouldy
    oldmouldy over 13 years ago
    You must have an out of date copy of the document, the 16.5 version, July 2011 has 'sameNet as a valid g_domain for axlCNSCreate - page 930
  • Mstrghettorigg
    Hi Oldmouldy,
    Thanks for the help.   I think the document I have is still for 16.3 since that's the version we currently have.
    I kept trying SameNet and same_net rather than sameNet.
    It is working now.
    Thank you!
  • fxffxf
    fxffxf over 13 years ago
     FY... axlCnsList(nil) will return a list of all supported domains: (spacing physical electrical sameNet)
  • Mstrghettorigg
    Hi fxffxf,
    Could you give me an example of how to string axlCnsList together to display the results?
    I've placed it in few places to try it out, but nothing is showing up or I'm missing it.
    Thanks in advance.
