  3. axlselect not getting cancelled using popup menu Cancel...
  • Subscribers 163
  • Views 18680
axlselect not getting cancelled using popup menu Cancel option
pcbnagaraj
pcbnagaraj over 13 years ago
All,
 I am defining a popup to cancel axlselect in the interactive mode .. I need to twice select Cancel in the popup to exit the axlselect command.
How to  determine the axlselect command is exited – tried using axlOKToProceed() while axlSelect command is active it returns ‘t’
 Below is the code.. what am I missing?
 Appreciate your help.
 procedure( testpopup()
 mypopup = axlUIPopupDefine( nil '(
("Next", "myNext()" )
("Oops", "myOops()" )
("Cancel", "myCancel()" )
("Done", "myDone()" )
axlUIPopupSet(mypopup)
axlSetFindFilter(?enabled '(noall symbols) ?onButtons '(noall symbols))
dbids= axlGetSelSet(axlSelect(?prompt "Select components"))
if(dbids then
axlUIWPrint(nil "- symbol selected -")
else
axlUIWPrint(nil "- symbol not selected -")
 ) ; end procedure
 procedure( myNext()
axlUIWPrint(nil "- Next -")
 procedure( myOops()
axlUIWPrint(nil "- oops -")
 procedure( myCancel()
axlUIWPrint(nil "- Cancel -")
axlCancelEnterFun()
axlUIPopupSet(nil)
procedure( myDone()
axlUIWPrint(nil "- Done -")
Nagaraj.
  • pcbnagaraj
    Thanks Dave.. Let me review the code and axlSelect logic used.
    Good day!
    Nagaraj.
