  3. axlselect not getting cancelled using popup menu Cancel...
  • Subscribers 163
  • Views 18679
axlselect not getting cancelled using popup menu Cancel option
pcbnagaraj
pcbnagaraj over 13 years ago
All,
 I am defining a popup to cancel axlselect in the interactive mode .. I need to twice select Cancel in the popup to exit the axlselect command.
How to  determine the axlselect command is exited – tried using axlOKToProceed() while axlSelect command is active it returns ‘t’
 Below is the code.. what am I missing?
 Appreciate your help.
 procedure( testpopup()
 mypopup = axlUIPopupDefine( nil '(
("Next", "myNext()" )
("Oops", "myOops()" )
("Cancel", "myCancel()" )
("Done", "myDone()" )
axlUIPopupSet(mypopup)
axlSetFindFilter(?enabled '(noall symbols) ?onButtons '(noall symbols))
dbids= axlGetSelSet(axlSelect(?prompt "Select components"))
if(dbids then
axlUIWPrint(nil "- symbol selected -")
else
axlUIWPrint(nil "- symbol not selected -")
 ) ; end procedure
 procedure( myNext()
axlUIWPrint(nil "- Next -")
 procedure( myOops()
axlUIWPrint(nil "- oops -")
 procedure( myCancel()
axlUIWPrint(nil "- Cancel -")
axlCancelEnterFun()
axlUIPopupSet(nil)
procedure( myDone()
axlUIWPrint(nil "- Done -")
Nagaraj.
  • DE202408202727
    DE202408202727 over 13 years ago
    Hi Nagaraj,
    For starters replace the line:  dbids = axlGetSelSet(axlSelect(?prompt "Select components"))
    with: axlSelect(?prompt "Select components") dbids = axlGetSelSet() axlClearSelSet()
    Dave
  • pcbnagaraj
    Thanks Dave for looking into this, but still the behaviour is same. I need to cancel twice using pop-up->Cancel to get out of axlSelect() command.
    Tried with 'noappmode' but no luck. Contacted Cadence support for their suggestion.
    axlCancelEnterFun()
    axlUIPopupSet(nil)
    axlShell("noappmode")
  • D912349
    D912349 over 13 years ago
    Hi Nagaraj,
    Instead of using axlSelect, try using this:
    axlSetFindFilter(depends on your selection)
    axlEnterPoint()
    axlSingleSelectPoint(axlLastPick(nil) for single selection or axlAddSelectPoint(axlLastPick(nil) if you want to group
    dbidSelected = axlGetSelSet().
    based on my experience, this code is easier to control instead of axlSelect.
  • pcbnagaraj
    The axlSelect will allow me to do window selection, tempgroup and is same as in Move/copy comand.
    axlEnterPoint will select comonents at single point.
    Wondering is there no way to exit axlSelect() in single command or its the limitation with User pop-up defined.
    Nagaraj.
  • DE202408202727
    See attached for a working implementation of axlSelect
    attachObjects_public.zip
