  3. Extract UI information in SKILL program
  • Subscribers 166
  • Views 17097
Yann00
Yann00 over 13 years ago
Hi all,
Well i am in allegro PCB Design,
I go tools/reports/New then i save Board_ACCURACY, Board_extents, Board_units,
etc... and i put that on text file.
I know how to do that with the user interface, but I need to translate that in
SKILL program in order to automate this informations record.
Could anybody help me?
Best regards,
Yann
  • skillUser
    skillUser over 13 years ago
    Hi Yann,
    First it would be best to post to the correct forum, PCB SKILL
    I have no knowledge of how Allegro operates so I cannot really comment.  In the IC tools we create a CDS.log file which contains all of the commands that were issued (through menus, bindkeys, form entries etc.) and so this information might help you in your task if Allegro has a similar kind of logfile?
    Hope this helps.
    Lawrence.
    I'll move this to the PCB SKILL forum.
  • GIL2004XP
    GIL2004XP over 13 years ago
    To change Units and Design accuracy use "axlDBChangeDesignUnits" and to change Design Extents you can use the skill function "axlDBChangeDesignExtents" You can refer to Allegro® User Guide: SKILL Reference for these functions.
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    From within skill you can use axlExtractToFile to extract data.
    It takes an "extract command file" as input - so you take whatever is in your command file and write that to a file inside skill and then run axlExtractToFile.
    That works really nicely.
    See attached file and remove 3 .txt command files and change the last one to suit your needs.
    Best regards
    Ole
    ns_camcad.zip
  • Yann00
    You help me a lot Ejlersen.
    Have you ever use a file.dra?   If you did, could i use axlAttachedFile to write into?
    thank you for your time.
    Best regards,
    Y
