  3. problem on deleteFile
  • Views 14971
D912349
D912349 over 13 years ago
Hi everyone,
 I encountered a problem whenever i use the deleteFile function, the code goes like this.
file = file and directory that should be deleted..(example: "C:/text.text")
deleteFile(file)
every time i run the program, an error is displayed.. error is:
E- *Error* deleteFile: permission denied -  "C:/text.text"
any help will be much appreciated
thanks in advance
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    Whenever I've run into this problem it has been due to the file not being closed or being open by another programs.
    So check if you've closed the file or maybe your skill code opens the file in a viewer or external program?
    Best regards
    Ole
  • D912349
    I will check my code first..
