  3. removing duplicate items on a list
  • Views 18195
D912349
D912349 over 13 years ago
Hi everyone,
Is their a function that that removes duplicates in a certain list?.
example:
input list is..
listWithDuplicate = ( "a" "b" "c" "d" "a" "c" "d" "a" "a")
after running the certain function, the output should look like this..
newList =  ( "a" "b" "c" "d")..
I am thinking of using looping statements but using loops will affect the time to run the program specially when the list consist of many items..
Thanks in Advance..
  • GIL2004XP
    GIL2004XP over 13 years ago
    You can try using the foreach function, see code below;
    newList = nil
    foreach( sel listWithDuplicate
    if( (member(sel newList) == nil) then
    newList = sort(cons(sel newList) 'alphalessp)
  • D912349
    Thanks GIL2004XP But what i need is a more straight forward function or maybe a built in function from allegro (if ever it exist).. My main concern is to decrease the time it takes for the program to remove duplicates, a list with 5 items will run fast.  but if my input is around hundreds or maybe thousands, I think it will run slower..
  • knuhcrek
    knuhcrek over 13 years ago
     Since you're trying to create a list of unique elements, why not use the unique() function? Something like
    newList = unique( listWithDuplicates)
    Another method would be to create a table and use the elements of listWithDuplicates as the keys. Then read all the keys into newList.
    Merry Christmas,
    Chris Walters
    rusty Cadence guru
  • D912349
    Thanks knuhcrek. unique function works perfectly. One more thing knuhcrek, can you tell me which documentation can I find the unique function??..
  • eDaNoy
    eDaNoy over 13 years ago
    In addition to unique function, there is no compiled documentation about this function.
