  3. OrCAD PCB Editor 16.6 Error
  • Replies 15
  • Views 26075
David Yackman
David Yackman over 13 years ago
I was just curious if anybody has run into this yet.  I installed the 16.6 upgrade last week, and it seemed to work just fine.  This morning, when I tried to double-click a board (.brd) file to make some edits, I got an error message that says "The program can't start because cdn_xerces-c_2_7.dll is missing from your computer.  Try reinstalling the program to fix this problem."  But, if I open up OrCAD PCB Editor and then click "File" and "Open" and then browse to the file it will open it that way. It didn't do this to me last week when I first installed the upgrade.  Right now, all of my existing board files were generated using the previous 16.5 version of software.
 Has anybody else had this problem?
  • TH Designs
    TH Designs over 13 years ago
    Hi Dave,
    Sounds like your Windows path for the .brd extension is still pointing to the 16.5 application.
    Tom
  • David Yackman
    Thanks, Tom.  Wouldn't happen to know how to fix it, would ya?   I've left a message for tech support, but I haven't heard back from them yet...  If they come back with a solution, I will post it here.
  • TH Designs
    You need to find the Windows configuration settings for file association. In older versions of Windows it was under Control Panle, File / Folder settings I believe. The extension ".brd" would have a path associated to it which is probably still pointing to the 16.5 executable.
    Tom
     Update: Look here: Control Panel, Default Programs - Set Associations
  • fxffxf
    fxffxf over 13 years ago
    You may have assigned the brd to program association manually.
    You should use the switchversion program (in the Cadence Start menu) to assign the association. This way as you switch between releases the association will automatically also switch
  • TH Designs
    You can switch between 16.5 and 16.6?
    I thought the switch release was only to go back to 16.2.
