  3. Read position from text file
  • Views 16573
Yann00
Yann00 over 13 years ago
I have to read a text file in my skill program.
My text file is:
X = 40      Y=60
It's a position, and i have to read the value to fill a variable in a function, in my SKILL program.
How I can I do please?
Best regards
  • D912349
    D912349 over 13 years ago
    Hi Yann00,
     The question is quite confusing, are you refering to getting the content of a text file(.txt) or get information of an existing text in a boardfile?
    If you are refering to an existing text on board file, you can use the following codes.
    note: make sure that layer of thee text is active.
    axlSetFindFilter(?enabled `("noALL" "text") ?onButtons `("noALL" "text"))
    axlSingleSelectPoint(x:y)
    textDbid =  car(axlGetSelSet())
    variable textDbid contains all anfo of the text. You can noew use different  attributes to extract whatever you need
    Hope this helps
  • Yann00
    Hi D912349,
    In fact I want to get the content of a text file(.txt).
    The  text file(.txt) is like that: X = 40   Y = 60
    And I want to get the content (  X = 40   Y = 60) to put that in a variable in my SKILL program.
    I need really to get this position to do my SKILL program. This position will be useful in my SKILL function.
    Do you understand what I try to mean?
    Thank for your help.
    Yann
  • DE202408202727
    DE202408202727 over 13 years ago
    Try using the fscanf command.
    eg:
    port = axlDMOpenFile("MISC", "abc.txt", "r")
    fscanf(port, "x = %d y = %d\n", x, y)
    axlDMClose(port)
  • D912349
    I tried the code of eDave and it works perfect. But i have one question, If I have multiple values of x and y per line at the text file can the same code extrcat all of them?.
    for extracting contents of a text file, I use this code
    variable txtFile is the input file directory and file name
    file=infile(txtFile)
    gets(tmpLine file)
    It stores one line at a time at variable tmpLine.
    the number of times you enter gets(tmpLine file) determines which line in the text file is extracted.
  • Yann00
    It works nicely.
    Thanks a lot
