  3. Modify a file.osm
  • Views 18056
Modify a file.osm
Yann00
Yann00 over 13 years ago
Hi guys,
I wanna modify a file.osm which contains my board outline. (see attachment).
I wanna open the file.osm and then get the text (see the attachment) to modify it. (Maybe a batch method...)
When I modify the file.osm I can save the new.osm
Do you have any idea to do that?
Best regards
Board Outline.pdf
  • DE202408202727
    DE202408202727 over 13 years ago
    I wouldn't do it that way. I would either put a property on each of the text items that you want to change and then change the text from the board once the symbol is placed or use descriptive placeholders instead of xxxxx and, again, change them once placed.
  • Yann00
    Oh you always answer me Dave, again thank you very much.
    In fact The user open a file User.txt and write into the text which he wants to place. (See attachment).
    And after that, my border outline filled. I write in an existant file.osm. So I already place the symbol "border outline". Basically I already re-center it. What kind of function could modify the text property?
    I have to automatize that in my SKILL code.
    • User.txt
  • DE202408202727
    Try using axlDBChangeText (16.6). Finding the right text to change is the hardest part.
    I now remember that you can't attach a property to text so you will have to use another method.
  • Yann00
    Yeah I used the twin of this function (axlDBCreateSymbol)
    I give my SKILL code. I just can't open my file.dra
    In the Cadence CMD it's right but in my SKILL code it didn't work.
    How I can do please? It wanna 3 argument, but this function give us only 2 arguments.
    Write_Cartouche2.il
  • Yann00
    I give you my User.txt too
    • User_OK.txt
