  3. Text search and Text edit
  • Subscribers 166
  • Views 17439
serpens
serpens over 13 years ago
I want to create a simple SKILL utility for find and replace texts in the DB (for the project number in template, e.g.) and I want to ask if is there some easy way how to get all the dbid of the text in whole DB?
Thanks.
Miro
Edit: This is the best I can think of.
axlSetFindFilter( ?enabled list( "noall" "text") ?onButtons list( "noall" "text"))
axlAddSelectAll()
moAllTexts = axlGetSelSet()
  • serpens
    I've done this small routine, however it change the text only in the curently displayed layer. Is this normal behavior?
    Miro
    axlAddSelectAll()
    foreach( moAllTexts axlGetSelSet()
    if( moAllTexts->text == "TEST"
    axlDBChangeText( moAllTexts "CHANGED!")
      println( "DONE!")
    axlClearSelSet()
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    The best way to go around this is to use the invisible parameter, so that it searches and selects both on visible and invisible subclasses.
    axlSetFindFilter(?enabled list("noall", "text", "invisible"), ?onButtons list("noall", "text"))
    Best regards
    Ole
  • serpens
    Thanks, this solve it nice.
    Now I finding how to replace my texts and I found this:
    moTmp = pcreReplace( pcreCompile( moFindText) moAllTexts->text moReplaceText 0)
  • vramananx
    vramananx over 13 years ago
    /forums/T/14379.aspx
  • serpens
    Thank vramanax,
    I will look trough you code. But I think you have similar issue with your code as I describe in here http://www.cadence.com/Community/forums/p/25683/1322038.aspx#1322038
    Miro
