  3. How to know if via is on BGA area.
  • Replies 7
  • Views 17486
eDaJun
eDaJun over 13 years ago
Dear All,
Can anyone help me to get via on a single net if it is inside the BGA premises. Thanks.
  • DE202408202727
    DE202408202727 over 13 years ago
    I'm not sure exactly how much help you need...
    Try using the axlGeoPointInShape command with the via location and the BGA placebound shape as the arguments.
  • D912349
    D912349 over 13 years ago
    You can use axlGeoPointInShape as advised by eDave but you ca also use axlIsPointInsideBox as alternative if you do not have the datebase id of the BGA placebound.
    try this,
    point = viaDbid->xy
    box = BGAsymbolDbid->bBox
    ptIsInsideBGA = axlIsPointInsideBox(pt box)
    output will be t/nil
    Hope it helps.
  • eDaJun
    hi D912349,
    Thanks for the reply.. can i also know where to get  box = BGAsymbolDbid->bBox?
    if i only have the dbID of the via. Thanks.
  • D912349
    eDaJun,
    It is possible if the via have a connection to the BGA. but if the via have no connection to the bga, you have to extract dbid of the bga from list of the design symbols. you can use:
    designSymbols = axlDBGetDesign()->symbols -> list of all symbols in your design.
    after getting the list, you can now filter BGA symbols depending on unique characteristic of BGA.
  • eDaJun
    D912349,
    if my via is connected to a BGA how can i get BGA property "bBox"?..
