  3. axlChangeLayer documentation issue or are lines really ...
  • Subscribers 160
  • Views 15308
axlChangeLayer documentation issue or are lines really unsupported
Ejlersen
Ejlersen over 12 years ago
Hi
I'm working on a large number of package symbols where the subclass (not class) needs to be changed for number of lines.
Using the new axlChangeLayer (16.6) command that in the documentation should support both lines, clines, segments, shapes and text I keep getting the following error (nid is the object id)
axlChangeLayer(nid "PACKAGE GEOMETRY/ASSEMBLY_TOP")
E- (SPMHGE-522): Changing line to a different class is not supported.
Anyone that has used this command with succes?
Best regards
Ole
  • aCraig
    aCraig over 12 years ago
    Hi Ole,
     I just tried it and was able to change text from "CONDUCTOR/L1" to "CONDUCTOR/L2".It also worked for "CONDUCTOR/L2" to SUBSTRATE GEOMETRY/OUTLINE".
     Craig
  • Ejlersen
    Hi Craig
    That really is weird. I've cut my code down to basically nothing to show the issue that I'm seeing.
    Line 14-15 is where I do the copy of an object and then try to change layer of that object. (In my current code I changed this to axlDBCreateLine which works nicely, but it would be nice not to have to work with axlPath commands to do arcs)
    Best regards
    Ole
    ns_copyindra.zip
  • aCraig
    Hi Ole,
    It looks like you are trying to change the line to the same layer. When I tried this I get the same error as you.
    Craig
  • Ejlersen
    Hi Craig
    If you look at the dra file and code it should change from PG/Silkscreen_top to PG/Assembly_top
    Best regards
    Ole
  • aCraig
     Hi Ole,
    I can only get text to work, Both line and shape fail. Sounds like a bug.
    Craig
