  3. deleteFile function throws error if file is opened
  • Views 16056
Pawandeep
Pawandeep over 13 years ago
Hi, Is there any way to check if a txt file is opened by a user or not before using deleteFile() function?I want to delete a file but if the user has already opened a file then deleteFile() functions shows error and the program halts. Regards,
Pawan
  • Ejlersen
    Ejlersen over 13 years ago
    Hi Pawan
    Use the command isWritable to check if you can write to the file, if that's the case then it is not readonly :-)
    Best regards
    Ole
  • fxffxf
    fxffxf over 13 years ago
     try: errset( deleteFIle( <filename> ))
  • Pawandeep
    Thanks for your suggestions. Regards,
    Pawan
