  3. Allegro Constraints-relative propagation delay
  • Subscribers 166
  • Views 22759
Redskins
Redskins over 13 years ago
Can someone explain in general what the definition of delta/tolerance is when adjusting for matched lengths in the constraint manager in Allegro? Thank you!
  • tltoth
    tltoth over 13 years ago
     Difference in length of the traces in units of mil (mm etc.) or in percentage.
  • Redskins
    Thanks, could you please give me a little detail please...Let's say I have a constraint setting of 5:100 vs 25:100, please explain the difference...Thank you!
  • mcatramb91
    mcatramb91 over 13 years ago
    Here is a recent thread on this topic that may be able to answer some of your questions:
    /forums/p/24764/1318896.aspx#1318896
    Setting the Delta:Tolerance field to 0.000mil:100.000mil means the longest net in the group could be 100mils longer than the target net and the shortest net in the group could be 100 mils shorter than the target.  So across all the nets you could have a variance in length as much as 200mils before seeing a DRC. (+/-100mil)
    Setting the Delta:Tolerance field to :100.000mil (blank Delta field) means that all the nets could have a variance in length as much as 100mils with no specific Target.  This is sometimes harder to match the members and could cause you to overly lengthen the nets.
    Hope this helps,
    Mike Catrambone
  • MikeGnieski
    MikeGnieski over 5 years ago in reply to mcatramb91
    Hi Mike..... if the Delta:Tolerance is set to 0.000mil:-100.000mil what does that indicate?
