  3. Can't get popup to gray Oops
  • Views 2169
aCraig
aCraig over 13 years ago
I have a popup definition like this:
(setq userData (axlUIGetUserData))
  (putprop userData userData->popupId 'oldPopup)
  (setq popupList (axlSelectPopupList))
  (setq popupList (cons (list "Next" 'CAL_cvnNext) popupList))
  (setq popupList (cons (list "Cancel" 'CAL_cvnCancel) popupList))
  (setq popupList (cons (list "Oops" 'CAL_cvnOops) popupList))
  (setq popupList (cons (list "Done" 'CAL_cvnDone) popupList))
  (setq popupFull (axlUIPopupDefine nil popupList))
  (putprop userData popupFull 'popupFull)
  (setq popupNoOops (axlUIPopupDefine nil popupList))
  (putprop userData popupNoOops 'popupNoOops)
  ;Now activate the initial popup with "Oops" and "Next" grayed out
  (axlUICmdPopupSet popupFull)
  (axlUIPopupSet popupNoOops)
When this code is executed the popup will have Next and Oops grayed out, When a start transaction occurs I execute (axlUIPopupSet popupFull) and nothing is grayed out. If I rollBack this transaction and there are no more transactions to roll back I execute (axlUIPopupSet popupNoOops). But it doesn't gray out Next or Oops.
 Anyone with any ideas on why it's not graying out Next or Oops?
Craig
  • DE202408202727
    DE202408202727 over 13 years ago
    Hi Craig,
    I haven't had a good look at your code yet but check for the declaration of
    local variables. You may need to declare your transaction mark variable
    (and others) as global.
    Cheers,
    Dave
  • aCraig
    Hi Dave,
    I build a smaller test case and got it to work. Now I just need to translate that back to the orignal program.
    Craig
