  3. Tab key path
  • Views 14924
Tab key path
aCraig
aCraig over 13 years ago
Does anyone know how to define the path the tab key takes in a form on each press?
Craig
  • fxffxf
    fxffxf over 13 years ago
    This is automatic. For all active fields:
    It will go left to right, top to bottom, unless it encounters a group box where it will stay within the box while it does left to right and top to bottom.
  • aCraig
    So what determines the order, FLOC?
  • fxffxf
     The x/y position of the fields in the form.
