  3. Extract information from pins of a certain spacing class...
  • Views 14736
Extract information from pins of a certain spacing class property
mesaman000
mesaman000 over 13 years ago
Hi everyone,
    From my previous post I've found out how to color pads and vias of the certain spacing class that I'm looking for.  As the title states, now I'm trying to extract and print information from those nets to a report.  Basically I want to parse through all of the nets and filter out/select all of the pads/pins with that spacing class property which I do by using this code:
  axlClearObjectCustomColor(axlDBGetDesign() ->nets)
;Select all nets/pins
axlSetFindFilter( ?enabled (list "noall" "pins"  "invisible")  ?onButtons (list "pins"))
axlAddSelectAll()
pins = axlGetSelSet()
csetNets1 = axlSelectByProperty("net", "SPACING_CONSTRAINT_SET", "TYPE1")
;;Extract which nets have the spacing class property "TYPE1"
cset1_pins = setof(pin, pins, member(pin ->net, csetNets1))
etc.
From there I want to  take csetx_pins and print them out to a report.. I want the report to look like this:
Report
CurrentTime : Mar 25 09:31:46 2013
Pin name x coord        y coord Mirrored? Rotation            SPAC_CLASS PAD_NAME Net_name
Q7.2 58.5 23.0 NO  270 degrees TYPE1 SR061X046 CONT_+3.3V
C1807.2 26.0 23.0 NO  270 degrees TYPE1 SR110X100 CONT+5V
Q2.1  42.0 23.0 NO  270 degrees TYPE2 SO220X064 GND
Q3.2 58.5 23.0 YES  270 degrees TYPE1 SR061X046 CoNT_+3.3V
C17.2 26.0 23.0 YES  270 degrees TYPE2 SR110X100 CONT+5V
Q9.1  42.0 23.0 YES  270 degrees TYPE3  SO220X064 GND
As you can tell I'd like the report sorted by the mirrored property first to determine which pins are on the back of the board and the front of the board.  Then I'd like to sort the report by spacing class (TYPE1, TYPE2, TYPE3)
 Here's what I have so far:
 cl_file = outfile("net_list.rpt" "w")
; ------ Print Header
fprintf(cl_file "**********************\n")
fprintf(cl_file "Report\n")
fprintf(cl_file "**********************\n\n")
; ------  Print CurrentTime
fprintf(cl_file "CurrentTime : %s \n" getCurrentTime())
; ------  Print column headers
fprintf(cl_file "Pin name \t x-coord \t y coord \t Mirrored? \t Rotation \t Spacing class \t Pad type \t Net name\n")
fprintf(cl_file
"====================================================================================================================================\n")
design_dbid=axlDBGetDesign()
l_comp_dbids=design_dbid->components
foreach(comp_dbid l_comp_dbids
ref_des=comp_dbid->name
symbol_dbid=comp_dbid->symbol
xy_loc=symbol_dbid->xy
;pins= symbol_dbid->component->pins
mirrorstatus=symbol_dbid->mirrorType
rotationstatus=symbol_dbid->rotation
;padid=axlDBGetPad(symbol_dbid,"ETCH/TOP","REGULAR")
fprintf(cl_file "%s \t\t %L\t\t %s\t\t %4.0f degrees \n" ref_des xy_loc mirrorstatus rotationstatus)
close(cl_file)
Can anyone help guide me in a more efficient direction because it seems like this is not the most efficient method..
Thank you very much!
  • fxffxf
    fxffxf over 13 years ago
    From an efficiency standpoint look at the following:
    1. get all nets  axlDBGetDesign()->nets
    2. for a net, get all pins on the net use the API: axlPinsOfNet(net 'pin)
    3. cset assigned to net (this assumes you have a dbid of a net assigned to a variable "net")
    net->prop->SPACING_CONSTRAINT_SET
    You would need to do more work get to the spacing cset is assigned using groups (netclass, bus, diffpair, etc.) For example, you place the nets into NetClass' and then assign the spacing cset at the net class level. You can use
           axlNetClassGet(...)
    after step 2 and then get the  SPACING_CONSTRAINT_SET off of the netclass
