  3. encrypter skill
  • Views 16657
encrypter skill
seyerfred
seyerfred over 13 years ago
Hi
i want to write a skill to encrypt my skill file but my code doenst wok.. please help..
here is my code:
 (defun encrypt ()
file = axlDMFileBrowse(nil nil ?optFilters "Skill files(*.il)|*.csf|Dat files(*.dat)|*.dat|)("?title"Select Skill file to Encrypt"))
if(!isDir("~/skill/encrypt") then
   createDir("~/skill/encrypt")
fileparts = axlDMFileParts(file)
filepartsFileWext = nth(2 fileparts)
fileEncParts = strcat("~/skill/encrypt/" filepartsFileWext)
encrypt(file fileEncParts eLock)
axlCmdRegister("encrypt" 'encrypt)
  • aCraig
    aCraig over 13 years ago
    Couple of things. First "encrypt" is a reserved word so redefine your function, maybe "myencrypt". Second the syntax is wrong for axlDMFileBrowe.
    Craig
  • Pawandeep
    Pawandeep over 13 years ago
    I made changes to your program-See attachment.
    -Pawan
    myencrypt.il
  • seyerfred
    Thanks craig and pawan...
     program still not functioning...
  • Pawandeep
    Try to provide the Absoulte Path to the files instead of Relative path and see if it helps.
    -Pawan
  • aCraig
    Try this:
    (axlCmdRegister "myencrypt" 'myencrypt)
    (defun myencrypt ()
    (let (file fileparts filepartsFile fileEncParts)
      file = axlDMFileBrowse(nil nil ?optFilters "Skill files (*.il)|*.il|)" ?title "Select Skill file to Encrypt")
      (when file
        (unless (isDir "./encrypt")
           (createDir "./encrypt")
        fileparts = (axlDMFileParts file)
        filepartsFile = (cadr fileparts)
        fileEncParts = (strcat "./encrypt/" filepartsFile "-enc.il")
        (encrypt file fileEncParts "eLock")
