  3. Segment Length
  • Replies 8
  • Views 20232
Segment Length
eDaJun
eDaJun over 13 years ago
 Dear All,
Can anyone help me hot to get this given point. Thanks
Capture
  • DE202408202727
    DE202408202727 over 13 years ago
    What are the known start values/points?
    What "point" do you want returned?
  • eDaJun
    Dear eDave,
    The points with arrows of two segments is the one that I would like to know.
    The segments where to points are close together...
    Please see the line and the pointing arrow for the segment length i want to know. Thanks
  • DE202408202727
    OK, that's not too difficult.
    You need to calculate perpendicular lines from the two vertices then calculate the distance between the points where these lines intersect one of the segments. The following code should help you.
    defun( DE_linePerpendicular (m1, x, y)
     let((m2, b2)
    cond(
    (!m1, list(0, y))
    (axlGeoEqual(m1, 0), list(nil, x))
    (t, m2 = -1.0 / float(m1), b2 = y - m2 * x, list(m2, b2))
    defun( DE_LineLineIntersect (m1, b1, m2, b2)
     let((x)
    ;  Returns x,y intersection of line
    ;     y = m1 x + b1
    ;  with line
    ;     y = m2 x + b2
    ;  Returns nil if no or infinite no of points (i.e. m1 = m2)
    ;  m1x + b1 = m2x + b2
    ;  x = (b2 - b1)/(m1 - m2)
    ;  y = m1 x + b1
    cond(
    (!m1 && !m2, nil)
    (!m1, list(b1, m2 * b1 + b2)) ; ie. x = b1 for first line (not both nil!)
    (!m2, list(b2, m1 * b2 + b1)) ; ie. x = b2 for 2nd line (not both nil!)
    (m1 == m2, nil)
    (t, x = (b2 - b1) / (m1 - m2), list(x, m1 * x + b1))
    defun( DE_LineEquation (pt1, pt2)
     let((m, b)
    ;  Returns (m, b) s.t. y = mx + b is the equation for the line joining points (x1,y1) and (x2,y2)
    ;  Returns (nil, x) if vertical
    m = axlLineSlope(list(pt1, pt2))
    b = if(m then cadr(pt1) - m * car(pt1) else float(car(pt1)))
    list(m, b)
  • eDaJun
    Dear eDave,
    what will be may value for m1,x,y?
  • DE202408202727
    m1 is the slope of the line (given by the DE_LineEquation function).
    x:y is a point on the line segment
