  3. Find the angle between two segments
  • Views 18021
eDaNoy
eDaNoy over 13 years ago
angle
I would like to get the angle between two segments, this must be applied to any angled situation.
I have already a function that gets the slope of two segments then the rest is a problem, i cant get the correct result
im using this formula.
angle=(m2-m1)/[1+(m2*m1)]
atan(angle)*180/math.pi
the result must be the added angle of two segments.
sample 1st segment = 90 degree
second segment = 45 degree
 result = 135 degree
  • DE202408202727
    DE202408202727 over 13 years ago
    There are some complex ways to do this but there is an undocumented command that you might be able to use:
    _axlAngleBetweenLines(list(pt1, pt2), list(pt3, pt4))
  • eDaNoy
    thanks Dave, i added some method to get the value that i want. _axlAngleBetweenLines result was in radian 180-_axlAngleBetweenLines()*180/math.pi gives me accumulated angles thank you so much. one more thing where could i find undocumented axl? maybe or somehow Im already in this kind of situation trying to figure out something which is already done.
  • eDaNoy
    Dave,
     Is it safe to use undocumented axl?
  • DE202408202727
    There's no easy way of finding undocumented commands and there is no guarantee that they will always exist. USE WITH CARE.
    However, when you do find one that is useful, put in an enhancement request to Cadence to get it made public.
  • eDaNoy
    thanks dave
