  3. artwork film control
  • Views 16903
seyerfred
seyerfred over 13 years ago
is there any code to set only all inner layer into supress unconnected pads? and a selection of plot mode for power/gnd plane to set posive o negative?
Thank you
  • oldmouldy
    oldmouldy over 13 years ago
    You can control the unused pads suppression from Setup>Unused Pads Suppression, check the options to suppress the pads as required.
    You can control the Artwork for planes through Setup>Cross-Section but you probably want to stick with positive.
  • seyerfred
    im making a skill for set-up general parameters that can select either positive or negative plane will use in plot mode and to set suppress all inner layer. ihave this code and form that can select positive or negative but dont know how to call the checkbox..
     fprintf(Gerber_Tool_Form "FIELD cmdSetArtParam\nFLOC 3 24\nMENUBUTTON \"set-up general param\"2 4\nENDFIELD\n")
    fprintf(Gerber_Tool_Form "FIELD chknegative\nFLOC 3 27\nCHECKLIST\"negative_plane\"\nENDFIELD\n")
    fprintf(Gerber_Tool_Form "FIELD chkpositive\nFLOC 3 29\nCHECKLIST\"positve_plane\"\nENDFIELD\n")
    (defun initSetParamR74x ()
    axlUIWPrint(Form "Setup Artwork Param!")
    (out = outfile("./initSetParamR74x.scr"))
    fprintf(out "%s\n" "setwindow pcb")
    fprintf(out "%s\n" "trapsize 2435")
    fprintf(out "%s\n" "film param")
    fprintf(out "%s\n" "setwindow form.film_control")
    fprintf(out "%s\n" "FORM film_control general_parameters")
    fprintf(out "%s\n" "FORM film_control format_int_places 2")
    fprintf(out "%s\n" "FORM film_control format_dec_places 5")
    fprintf(out "%s\n" "FORM film_control gerber_rs274x YES")
    if((deviceType == "1") then
       fprintf(out "%s\n" "setwindow form.film_control positive YES") else
       fprintf(out "%s\n" "setwindow form.film_control negative YES")
    fprintf(out "%s\n" "FORM film_control ok")
    close(out)
    axlShell("replay  initSetParamR74x.scr")
  • aCraig
    aCraig over 13 years ago
    It sounds like you need to write a Call Back Function for your form. There you can save the selection to use in your main function.
    Craig
  • seyerfred
    yes thats right, but how? i also add this cmd
    ("cmdSetArtParam"
    axlFormSetField(Gerber_Tool_Form "colSetArtParam"
       'green
    (setup_art_param)
    ("chknegative"
    (negative_plane_selected = (Gerber_Tool_Form->curValue))
    ("chkpositive"
    (positive_plane_selected = (Gerber_Tool_Form->curValue))
     please help.. thank you
  • aCraig
    Take a look at the example form code at <allegro_install_dir>/share/pcb/form/basic
    Craig
